Message 11 of 27
Re: SNR Margin
@Mapantz welcome back to the community, I'm really sorry to see you're experiencing issues with your broadband, if you've noise on the line then it will be causing the errors and instability. In response to this dynamic line management has likely increased the noise margin to stabilise the connection which unfortunately results in your speed decreasing.
I'll send you a private message so you can get in touch and we'll be happy to get this looked into and in the meantime, I'd recommend you don't try any further disconnects as that can make things worse.
Message 12 of 27
Re: SNR Margin
Things calmed down on Friday and Saturday. A few drop outs returned yesterday, but not too bad. Today however, drop outs are in abundance. Around 20 in the last few hours.
Heading towards thousands of error packets on both upstream and downstream.
https://warehamwx.co.uk/
Message 13 of 27
Re: SNR Margin
if dropping that often is noise on line even worse than before
Message 14 of 27
Re: SNR Margin
This is getting absolutely absurd now.
I have sat here and counted 30 drop outs in around 15 minutes. It just gets worse and worse...
How can this be going on since September and nothing being done to sort it?
BT promised me it would be fixed by Friday just gone. No one has phoned me, or emailed me - no contact whatsoever to keep me updated.
I'm at the end of my rag with all of this now and refuse to put up with it any longer. Paying £40 a month for this rubbish? and 1 star customer service?
I'm pretty sure this is Watchdog material?
I'm going to have to find other avenues to get this sorted - force the issue, as BT are doing nothing and have DONE nothing since September.
Message 15 of 27
Re: SNR Margin
That's just absurd!
I've tallied about 100 disconnects since early Monday morning. Getting on for 4 months with no end in sight. Thank you BT.
Message 16 of 27
Re: SNR Margin
do you have a dial tone?  stats suggested lots of noise/interference on your line
Message 17 of 27
Re: SNR Margin
Yes. I have a dialtone.
Message 18 of 27
Re: SNR Margin
I was just on the phone to BT, via mobile and I get cut off. I have no signal to make a call or a text now. Guess which network  I am with?
Also, that picture above is the speed I get from the 4G hub that BT sent me to "Stay connected"
The whole thing is farcical.
Message 19 of 27
Re: SNR Margin
if you have a dial tone  did you check for line noise by dialing 17070 option 2  should be silent
Message 20 of 27
Re: SNR Margin
Why do you keep asking me the same questions over and over? YES, there's noise on the line.. there's has been noise on the line for months....
