Message 1 of 3
Samsung A10
Hi,
When i do a speed test on the wifi with this device I get a maximum of 0.1mbps. Other devices om the same connection are getting considerably higher speeds. Can someone help me get the speeds higher?
Thanks,
B
2 REPLIES 2
Message 2 of 3
Re: Samsung A10
The A10 is in the lower performance range but receives good ratings.
How are you measuring the Connection speed?
Which version of Android is it?
For Android 10 and a slightly higher spec version of the A series:-
I found out by trial and error.
Disable mobile networks.
Disable NFC
Disable Bluetooth.
If you search the web, these are common recommendations
Look for an improvement.
Must admit that I don't use wi-fi much, as the mobile signal is good locally. Wi-fi  seems to drain the battery. Hence all my settings are biased towards improving battery charge life but there's no noticeable problem with data speeds.
Message 3 of 3
Re: Samsung A10
What speed test did you use?
