Message 1 of 205
Samsung tv app freezing
Has anyone got any advice on how to fix an issue we have with the BT Sport app on a Samsung TV?  Used to work fine, but now works for about a minute and then the picture freezes and audio continues.  Able to go back and start again but the same happens.  No issues with Netflix, Amazon Prime etc and the checker says there are no issues with the internet
204 REPLIES 204
Message 2 of 205
Re: Samsung tv app freezing
Are you watching BT Sport Ultimate?  (you'll see the Ultimate logo in the corner of the screen).  If so, then instead of clicking the match you want to watch from the front screen, try going across to the channels menu at the top and then select the channel it's on.  When asked if you want to watch on Ultimate, say no.
The problem with Ultimate at the moment is that it's only available in higher video quality, so if you have any bandwidth issues it can't keep up with the lowest available quality and switches to audio-only.
We're working on a solution.
Message 3 of 205
I don’t believe I have access to ultimate and the same issue happens if I select the channel from the list
Message 4 of 205
Sometimes there appears to be a timing issue when it happens too as the audio goes back about 30 seconds
Message 5 of 205
OK, these aren't issues we've heard of before.
Could you please provide your TV model number?
Message 6 of 205
UE55MU6400
Message 7 of 205
Same issue for me. Worked fine a few weeks ago, now the picture freezes after 30 secs but the sound continues.
TV model UE50MU6120
I've deleted and reinstalled the app, nothing changes. This happenes on all channels too
Message 8 of 205
I have the same issue.
Samsung Frame Model Code: UE49LS03N
Message 9 of 205
same thing happening with my samsung tv after about 30 seconds , I've deleted and reinstalled the app and no matter how you select how to watch it it happens on all live channels.
worked fine until today , i have a 300mb connection working fine so can't be a bandwidth or speed issue
the picture freezes the audio goes back in a 30 second loop
tv model UE65MU8000
ive rebooted tv as well
Message 10 of 205
Unfortunately, our ability to debug issues like this on Samsung TVs is limited. It isn't something we see on any of the devices we have, so we have no way of identifying the cause.
The advice we've been given by Samsung for issues like this is (test the app between each step):
1. Check for TV software updates
2. Reinstall the app
3. Factory reset the TV
If these steps fail, Samsung have advised that you should call their helpdesk and they can remotely control your TV to obtain further details on the cause of failure.
