Message 1 of 9
Setting up my Smart Hub 2
Hi,
I've recently placed an order for BT Fibre 1 and would like to make sure I have have everything ready.
From what I've read online, This is my Master Socket which I will need a Microfilter to separate the phone line and broadband?
Will I also need a modem? From my understanding our rented property doesn't have Fibre so that's the reason I went for BT Fibre 1.
Any help will be amazing.
8 REPLIES 8
Message 2 of 9
Re: Setting up my Smart Hub 2
that is the master and you just need to connect filter and then connect SH2 to the filter and that's it - connected
SH2 is a modem/router
Message 3 of 9
Yes, you will need a filter, no, you won't need a modem. The Smart Hub 2 is a combined modem and router.
Message 4 of 9
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Message 5 of 9
@licquorice  @imjolly  Is a filter no longer supplied with the SH2?
Message 6 of 9
I don't know but assumed for a new customer it would be included in the box with the SH2 along with modem cable.  unlike a replacement SH2 which will just come with hub
Message 7 of 9
The SH2 hasn't arrived yet, should be early next week
Message 8 of 9
Message 9 of 9
I got mine yesterday, all you need is in the box, takes 2 mins to set up. Hopefully mine activates today , fingers crossed
