Message 1 of 8
Settings for Router/Modem combination
Hello,
After upgrading from "Broadband Unlimited" to "Fibre 1" (FTTC), I'm happy with the speed,
however I don't trust the Smart Hub 2 regarding Wi-Fi: I opted out and I don't want it –
nevertheless it turned itself on after the upgrade, which I only noticed accidentally.
To avoid this in the future, I'm using my old wired (and very reliable) Billion BiPAC 7800 Router
(Gigabit Ethernet Switch, FTTH multi-service gateway, E-WAN port for VDSL or Fiber modems)
in conjunction with an old BT Openreach VDSL Fibre Modem (ECI) from eBay.
I changed the router settings to:
• EWAN
• PPPoE
• username = [email protected]
• password = bt
Which other settings should I optimise?
Please see 2 screenshots below (WAN & Firewall), but there are also other settings...
Many thanks!
7 REPLIES 7
Message 2 of 8
Re: Settings for Router/Modem combination
VLAN ID 101
Message 3 of 8
Thanks for your answer "VLAN 101". Where/how should I use this?
Message 4 of 8
2020-06-05 20_22_07-Settings for Router_Modem combination - BT Community.png
Message 5 of 8
Thanks, so that's it.  What does this "101" do?
Message 6 of 8
It's the ID of the VLAN.
Message 7 of 8
Thank you. I'm not familiar with VLAN details. Without this setting (nothing entered) it seems to work –
so what could happen if I would let it as it is, resp. what would it improve if I would enter "101"?
Message 8 of 8
If it works don't try to fix it.
