Message 11 of 16
Re: Simple question guys. How do I report a fault with my broadband.
everything is normal until we get an incoming call, then we lose the broadband for two minutes.  The rest of the time we get a dial tone on the phone as usual.   Afraid I have no idea what the test socket is.
Message 12 of 16
If you remove the lower faceplate portion of the master socket you will reveal a test socket. This is the demarcation point between your responsibility and Openreach's . You need to test from there to prove the fault is outside of your wiring.
Message 13 of 16
Do you still use a filter for your broadband? If so have you tried replacing it?  If you have extension socket do you filters in them if in use?
Message 14 of 16
You see this is my issue. I am not technical person. I have no idea if we have filters. i just want to report a fault and have BT fix it.
thank for your help though,
Message 15 of 16
thanks. but i am still unclear. if things are working normally except for the two minutes after an incoming call, how do I test anything?
Message 16 of 16
As you are not doing the checks then just phone 151 and report a phone fault and get engineer visit. Bear in mind if problem is internal then you will be billed for engineer visit £85
