Message 1 of 9
Sky Q problems / smart setup
Hi,
I appreciate this has come up before, but we have the problem of our Sky Q box disconnecting from the network every evening. I have tried many of the fixes suggested but one thing that seems to work for many people is switching off the smart setup on the hub. I have tried to do this but I can’t find where the option exists to do that - has it been removed?
Any help or suggestions would be much appreciated. Thanks I’m advance.
8 REPLIES 8
Message 2 of 9
Re: Sky Q problems / smart setup
have you turned of smart setup
Turn Off smart setup
I would also change the 5ghz network channel to manual from auto and select another channel to channel 36 which is used by SKYQ - try 44 or48
Message 3 of 9
Thanks for the reply. I’m just not able to see the smart setup option in the hub manager and that’s why I was wondering if it’s still there?
thanks for the other suggestion, will try that.
Message 4 of 9
which hub version do you have?
Message 5 of 9
It’s a smarthub 2. Thanks so much for the help.
Message 6 of 9
Still there
Message 7 of 9
I’m going to try firing up the laptop as I’m not getting that option on my phone! Thanks
Message 8 of 9
Yes that worked - that option just wasn’t showing on my iPhone but it was there when I connected on the laptop. I really appreciate you helping me out, thanks very much
Message 9 of 9
Go into wireless devices and assign each one to have that IP address permanently. DCHP leasing is for a 24hours by default,. this cause an issue whereby the mini boxes keep looking for the main box
