Message 1 of 4
Slow download speed compared to sync speed on Fibre 2
Looking for help, my router is showing a data rate of 15.307 Mbps / 62.153 Mbps and a maximum data rate of 15.307 Mbps / 63.490 Mbps but the download speed checker is only giving me 14.13 Mbps / 55.12 Mbps. Is it possible there is an issue with my profile or something as it looks to me that I should be getting faster downloads? How do I getthis looked at?
3 REPLIES 3
Message 2 of 4
Re: Slow download speed compared to sync speed on Fibre 2
On a connection speed of 62mb  after allowing for line overheads a download speed of55mb is about right   was that check done using btspeedtester over ethernet?
Message 3 of 4
Yes it was
Message 4 of 4
There is no problem with your connection. The sync speed shows the "raw" speed of your connection, it does  include (as @imjolly  has stated) the necessary overheads  (data packets) that are required for your device to be able to communicate with the internet. A speed test will show your connection speed but not include those data packets that are necessary. That is why to see a difference between sync speed and speed checker results.
