Message 1 of 9
Smart Hub 2 Manager and LAN devices
As from yesterday, I'm a new Fibre 2 customer. I have successfully connected all my 26 LAN devices to my BT Smart Hub 2 and all appear to be working OK. 9 devices are ethernet connected and the remaining 17 devices are wireless.
However, under Smart Hub 2 Manager > Home > Advanced settings > My network > My devices
I see:
Ethernet connections: Devices - 0
BT Smart Hub: Devices - 26
Wireless connections: Devices - 26
Please can anyone explain why all devices are listed as wireless? TIA.
8 REPLIES 8
Message 2 of 9
Re: Smart Hub 2 Manager and LAN devices
Simple. The BT hub network list is hopeless.
Message 3 of 9
Mine does quite the opposite, showing WiFi devices as ethernet.
Bonkers! 🙂
Cheers
Ted
Message 4 of 9
That is usually because of devices connected via powerline adapter WiFi hot spots.
Message 5 of 9
No powerline adapters in use.
Message 6 of 9
They wouldn't explain your problem, it would possibly explain @@supertedster  problem
As previously stated, the network details are not to be relied on, it has always been a problem with all home hubs that never seems to get resolved.
Message 7 of 9
In my case I suspect it's because, I have "Complete WiFi" disks connected over ethernet. So the "Dumb-Hub 2" sees any devices connected to them as ethernet.
Cheers
Ted
Message 8 of 9
Just as an update to this.
I changed the channel numbers of both WiFi bands. All my devices now show their correct connection methods.
Why rebooting the SM2 doesn't achieve this, beats me?
Cheers
Ted
Message 9 of 9
I think I answered that in message 2 😃😃
