Message 11 of 17
Re: Smart Hub 2 WiFi Speed
Here's some stats from my Mac to show what's happening.
Message 12 of 17
So its not a wifi problem, its a throughput problem. Don't forget FTTP is a contended service.
Message 13 of 17
It's not a throughput problem because I can get over 900Mbps on Ethernet.
It's a WiFI bandwidth issue due to using the WiFi 5 standard.
No contention issues on the WAN for me.
Speed test on Ethernet to back this up:
11022224725
Message 14 of 17
I don't know where the throttle is, but it isn't a wifi5 bandwidth problem as your wifi sync speed is 866M.
Message 15 of 17
Bought a Ubiquiti WiFi 6 AP and I'm now getting real world WiFi speeds of over 720Mbps on devices with WiFi 6 support at 80MHz with 2x2 MiMo.
Message 16 of 17
@RDowson  hi,  can you give me a link of the product which you purchased ? I am having similar issues and planning to buy a new router. Thanks.
Message 17 of 17
As @RDowson  hasn't been on the forum for 2 years, you may not get a reply.
