Message 11 of 13
Re: Smart Hub 2 - control wifi access open to abuse
Bin the 'not at all' smart hub and replace it with a decent router that is capable of being configured how you need it
Message 12 of 13
@ianhoward27
You cannot "bin" it, as its on loan from BT and will need to be returned if you move to another provider, otherwise you will be charged.
You also need it of you want a phone service from BT.
Message 13 of 13
Hopefully as you are posting on a two year old thread that the OP has already found a solution that meets his needs.
