Message 1 of 10
Smart Hub 2
Morning all, I'm having issues with a solid orange light. I've followed instructions numerous times and still no joy as it won't give me the setup wizard when I connect a device. When I check service through the app it says everything is fine and no faults, yet when I try to restart hub through the app it says unable to do so as there seems to be technical issues BT end? Thanks in advance
9 REPLIES 9
Message 2 of 10
Re: Smart Hub 2
@StuartGibson
Welcome to this user forum.
What type of broadband connection do you have. Is the home hub plugged directly into your phone socket, or does it connect to an Openreach optical modem?
Message 3 of 10
Re: Smart Hub 2
Thanks for the welcome.
Just a standard connection I think. It's plugged straight into the phone line in the kitchen where it was initially set up.
Message 4 of 10
Re: Smart Hub 2
Can you please check your phone line to make sure you still have dial tone, and there is no noise on the line?
Also dial 17070, and confirm that the number that is read out, matches your own phone number.
Message 5 of 10
Re: Smart Hub 2
I don't have a landline phone, I meant that it's plugged straight into the socket where the phone line would be. My apologies
Message 6 of 10
Re: Smart Hub 2
Then its going to be very difficult to prove whether you have a line fault or even a crossed line. If you do not get dial tone, or your line is crossed with another line, then you will not get any broadband. A crossed line could also mean that you are getting charged for another person`s phone calls.
If the fault has just happened, then its quite possible there is a fault on your line. A basic wired phone costs less than £10, and it useful in proving a fault, and also in an emergency, as you can use it to dial 999, and the operator will know your address right away.
All I can suggest is that you check all of the connections.
What does your master phone socket look like?
Message 7 of 10
Re: Smart Hub 2
It's the same as image 2
Message 8 of 10
Re: Smart Hub 2
That one is known to give intermittent faults.
Please connect things up as shown below, and see if it fixes the fault. As you do not have a phone, you will not be able to connect anything to the phone side of the microfilter.
NTE 5C Test socket checkNTE 5C Test socket check
Message 9 of 10
Re: Smart Hub 2
Now plugged direct into test socket it's flashing purple
Message 10 of 10
Re: Smart Hub 2
If it keeps on flashing purple, then you must have a line fault, as the test socket is the first point where your phone line terminates.
If it does not work at that point then you either have  a disconnected line or a crossed line. Anything before the test socket, is the responsibility of Openreach, who will deal with it, when BT raise a fault report.
The only way to prove it is with a phone, as if you do not get dial tone, then you can report it as a phone fault, and it usually gets fixed quickly.
The only other alternative is to report a broadband fault on 0800 800 150, and it will enter the broadband fault queue and go through the broadband diagnostics, which may or may not, detect a line fault.
