Message 1 of 6
Smart Hub 6 Manager-insecure connection
When using my Chromebook, if I try to connect to my Smart Hub 6 Manager it always says 'insecure connection!' do you wish to proceed'. I do click 'yes' regardless of the warning as that is the only way to arrive at the basic status interface.However, I wud like to know why I get this warning, espec ially with it being a BT Smart Hub Manager.
5 REPLIES 5
Message 2 of 6
Re: Smart Hub 6 Manager-insecure connection
this has been covered before and is because hub manager is only http and not https
Message 3 of 6
I did a search before posting, but cudn't find.
Does that mean I'm safe regardless to continue? 🤔
Message 4 of 6
yes you are safe to continue - never bothered me and I access daily
Message 5 of 6
The page is only accessible on your home's LAN and can not be accessed by others so is safe.
Message 6 of 6
OK, thanks to you both for that reassurance. 😊
