Message 1 of 6
Smart hub 2 - Sky Q
I keep losing connection on my SkyQ box every 3-4 days via wifi, having to go through the process of placing the  key for connection on my skyQ  box. Skyq box is around 8 mtrs away from hub.
Having visited the Sky forum it appears its a regular fault with hub 2s. I was thinking about connecting via Ethernet cable directly but do not have enough outputs on my hub.
Any ideas ?
5 REPLIES 5
Message 2 of 6
Re: Smart hub 2 - Sky Q
I have a SH2 and SKYQ with 3 minis all connected by WIFI and don't have any problems.  I would suggest that you select the channels manually rather then leaving on auto and also ensure you change hub from channel 36 to 44/48 as SKYQ uses channel 36
Message 3 of 6
Thanks for the reply.  " I would suggest that you select the channels manually rather then leaving on auto and also ensure you change hub from channel 36 to 44/48 as SKYQ uses channel 36"....Can you offer i bit more detail on how to perform the changes please ?
Message 4 of 6
Hi @starship   All you need is a simple Unmanaged Gigabit Ethernet Switch. Search a well known online retailer.  I have three of these between my Sky Q box and Mini boxes all connected by Ethernet.
Message 5 of 6
go to hub manager then wireless then change settings then select the different channel then save and exit
Message 6 of 6
Thank you, not made the changes just yet as have a stinking cold. but have found the details. many thanks.
