Message 1 of 2
Smart monitor and Google home
Hi, I have a bit smart monitor 5000. It says it works with Google home and to just say to Google to connect to smart monitor, when I try this it says that smart monitor is not available in my country. Does anyone know if it works in Ireland or not or if anyone else has had this issue before?
1 REPLY 1
Message 2 of 2
Re: Smart monitor and Google home
Hi @Conly, welcome to the forum and thanks for your post.
You would be best to get in touch with the Product Helpdesk and they'll be able to help you resolve this.
cheers
John
