Message 1 of 9
Smarthub 2
1.New Smarthub 2 arrived yesterday morning, I had received a telephone call the previous day from BT advising of this and informing me to just follow the instructions in the box and I would be "good to go" .
2.Removed my old BT Homehub3, installed new Smarthub 2 - no broadband!  re-installed old BT Homehub 3 and went online to double check my actions via video on BT website, I had done everything correctly.
3.Again removed old BT Homehub 3, Re-installed Smarthub 2 - again no broadband.  Repeated action as 2 above, and through checking on google and BT Community it appears I have to wait for BT to activate their product, after which I will be notified by text or email it had been activated.     Still No email or text to madvise.
Please, is there anyone out there who can advise how long it takes BT to arrange such a simple course of action and activate their own product?
8 REPLIES 8
Message 2 of 9
Re: Smarthub 2
did you remove the modem and connect the new SH2 direct to the phone socket  with filter if you currently use a filter
Message 3 of 9
Re: Smarthub 2
@JohnMutley_65
Did you connect the new home hub directly into your phone socket or microfilter?
I assume that you have a "fibre" connection, and must have been using an Openreach modem as well, is that correct?
Message 4 of 9
Re: Smarthub 2
Sure did, only one connection so I had to use the filter, the phone line was OK but no broadband.
Message 5 of 9
Re: Smarthub 2
Microfilter, and yes, I had an Open reach modem that should now be obsolete with SM2
Message 6 of 9
Re: Smarthub 2
So you are connected up as shown below?
Did you upgrade your broadband package?
Message 7 of 9
Re: Smarthub 2
did you just use the cable that was connecting the modem to the filter and connect that direct to dsl socket on back of hub?  if so did the start to boot up and what colour is hub light
Message 8 of 9
Re: Smarthub 2
Apologies for late response, other problems at home. No I did not upgrade my broadband package. I cannot now remember how it was resolved but I did get online eventually. Thanks for your advice/help.
Message 9 of 9
Re: Smarthub 2
Apologies for later reply, other problems at home.
I used the cables that came with the new hub, eventually after a very long period of time, (took the dog for a 15 minute walk) and later the colours began to change until eventually blue.
