Message 1 of 39
BT Smarthub 2 keeps disconnecting
My BT Smarthub 2 keeps disconnecting and reconnecting over the past 10 days, any ideas why?
38 REPLIES 38
Message 2 of 39
Re: BT Smarthub 2 keeps disconnecting
what have you tried to fix it?
quiet line test?
hub factory reset?
using test socket?
post some hub stats
Message 3 of 39
When you say “disconnecting” what do you mean? Is it rebooting? Is it disconnecting from the internet i.e. light goes orange? Or is it the wifi that is dropping?
Message 4 of 39
Hi @andreaferns120472,
Thank you for posting. I'm sorry if you've been experiencing disconnections.
If you can give us a few details about what happens as suggested by @Will168 and @imjolly, that will help to give us an indication of what is happening with your connection.
Thanks,
Paddy
Message 5 of 39
The hub flashes red then after about 8 minutes it goes back to stable blue.  This happens a few times during the day and evening.  Does that help?
Message 6 of 39
The Smarthub 2 flashes orange/red/purple not sure which then after around 8 minutes it changes to stable  blue when we are back online again.   This happens  a few times during the day and evening.  I have tried setting the hub back to factory settings but still same problem.
Message 7 of 39
try quiet line test  dial 17070 option 2 should be silent and best with corded phone
have you tried using test socket to eliminate any problems with internal wiring
post hub stats - hub manager/advanced settings/technical log information
Message 8 of 39
Hello
Thank you for your reply.  I have the technical log but how do I send this to you?
Message 9 of 39
Thank you for your reply.  I have the technical log here.  Look forward to hearing from you
Message 10 of 39
Hi @andreaferns120472 and thanks for posting.
Have you tried the quiet line test mentioned by @imjolly That will let us know if there is a line fault. Can you try that and let us know what you find?
Cheers
David
