Message 1 of 5
Smarthub2 horrendous siren sound
My elderly mother was forced to do the digital switch over a few weeks ago. New smarthub2 router.
This weekend she returned home to what "sounded like a police siren going off " in her lounge. As loud as a fire alarm. It was the Smarthub2 router and the sound only stopped when she turned the power off at the wall. No router sounds since and broadband working ok.
Has anyone else experienced this?
She now has no confidence in the router so turns it off when ever she leaves the flat or when she goes to bed.
4 REPLIES 4
Message 2 of 5
Re: Smarthub2 horrendous siren sound
@jgtaylor42
The sound would have been coming from one of the phones that had been left off the hook, or not been disconnected after the last call.
Its a sound coming from the network to indicate that the line has not been cleared down.
If it happens again, ask her to check which phone its coming from, and replace the handset.
Message 3 of 5
Thank you so much for your reply.
I had wondered if it was the phone not the router as phones are more likely to be able to emit that kind of sound. They are right next to each other so I could imagine her wrongly mixing up the source.
But she assures me the sounds was unbearable and would have woken up people in adjacent flats and not just a normal notification when a receiver is not put down correctly.
We have replaced the brand new BT phone back with the previous BT one and will see what happens.
Out of interest I went into Smarthub2 technical log and there are lots of entries labelled 00:00 01 Oct when she had the siren sound sometime between the real time of 07:29 05 Dec and 07:47 05 Dec (when she restarted the hub ok). I've looked at the complete technical log for the hub and 00:00 01 Oct has never appeared at any other time on hub restart. Could this be relevant at all?
123607:47:3305 Dec.     5G   WiFi UP
123707:47:2605 Dec. WAN Auto-sensing last connection port: DSL WAN
123800:00:1601 Oct. Booting firmware v0.30.01.08093-BT (Mon Aug 9 20:01:14 2021)
123900:00:1601 Oct. System start Button press (PowerButton)
124000:00:1601 Oct. System up
124100:00:0901 Oct. 2.4G WiFi scan(Reason:boot)
124200:00:0601 Oct. Hub has activated against the device management system
124300:00:0601 Oct. 2.4G WPS feature enabled
124400:00:0601 Oct. 2.4G WPA2 mode selected
124500:00:0601 Oct. 2.4G WiFi UP
124600:00:0601 Oct. 5G   WPS feature enabled
124700:00:0601 Oct. 5G   WPA2 mode selected
124800:00:0601 Oct. 5G   WiFi     UP
124923:59:5930 Sep. WAN Auto-sensing last connection port: DSL WAN
125000:00:2201 Oct. Booting firmware v0.30.01.08093-BT (Mon Aug 9 20:01:14 2021)
125100:00:1901 Oct. System start Button press (PowerButton)
125200:00:1901 Oct. System up
125300:00:1201 Oct. 2.4G WiFi scan(Reason:boot)
125400:00:0801 Oct. Hub has activated against the device management system
125500:00:0801 Oct. 2.4G WPS feature enabled
125600:00:0801 Oct. 2.4G WPA2 mode selected
125700:00:0801 Oct. 2.4G WiFi UP
125800:00:0801 Oct. 5G   WPS feature enabled
125900:00:0801 Oct. 5G   WPA2 mode selected
126000:00:0801 Oct. 5G   WiFi     UP
126100:00:0001 Oct. WAN Auto-sensing last connection port: DSL WAN
126207:29:5905 Dec. SIP p65544t1 SEND 180 INVITE
126307:29:5905 Dec. SIP p65544t1 RECV INVITE
126407:17:3405 Dec. SIP Registration - success
126507:00:0205 Dec. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=125.64.94.145 DST=81.154.66.195 LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=54321 PROTO=TCP SPT=59246 DPT=391 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Message 4 of 5
Message 5 of 5
Thank you again. That sound matches what was heard.
Not sure why it was so incredibly loud, but hopefully it will not happen again.
