Message 1 of 5
Smarthub2 not working with windows 10
Hi
We have just upgraded our ultrafast hub to a smart hub 2. Everything works except our windows 10 machine. It will connect fine and open some websites eg google. But it won’t open others eg bt.com.
When I check the network settings I seem to see ipv6 connectivity as internet but ipv4 connectivity as no internet. I’ve tried flushing dns etc.
Any ideas? We’ve switched back to the ultrafast hub for now as the windows machine is the one my youngest son does his school work on.
many thanks
David
4 REPLIES 4
Message 2 of 5
Re: Smarthub2 not working with windows 10
have you turned of smart setup
Turn Off smart setup
Message 3 of 5
Yep turned off smart setup...
Message 4 of 5
Disable and then enable your network adaptor.
Message 5 of 5
Yep tried disabling and enabling the network adaptor. Also flushing dns and tried setting a dns server from the computer. None of which helped unfortunately.
