Message 1 of 4
Sony Android TV - No App Available
Hi. I have a Sony Bravia Android TV and the BT Sport app is not available in the Play Store.
With the recent casting change I am reduced to watching BT Sport via my PlayStation.
Considering the TV I have, this is a bad experience from both Sony and BT.
Is it possible to get some sort of definitive answer about when or if we can expect BT Sport on Sony Android TV's?
3 REPLIES 3
Message 2 of 4
Re: Sony Android TV - No App Available
The BT Sport app is in the Play Store for all Android TV devices, as long as the account that the Play Store is logged in with is registered with a UK address.  Is there any chance yours has an international address on it?
You can see the app here: https://play.google.com/store/apps/details?id=com.bt.btsport
If you log into the web site in a web browser with the same account that you're logged into your TV with, it'll either show a green button that'll allow you to send the app to your TV, or it'll show you a message indicating that the app isn't available.
Message 3 of 4
@EveyHammond
Using the TV and Google Store:
NOTE : Mine reports OPEN as it is already installed.
Message 4 of 4
Thanks for the quick reply 🙂
The issue was the TV was not signed in to Google - a simple fix!
All sorted now, thanks for your help.
Cheers!
