Message 1 of 12
Star wiring tutorial
Good Morning,
Can someone please guide me step by step how to ‘star wire’ my connection? Could you please explain to me where the wires should be connected.
Does star wiring cause a change on the DLM?
I currently have incoming BT line connected to just 1 telephone socket (terminals 5 and 2) and I seem to be getting a internet connection with no master socket connected at all and no junction box. Strange but it works.
11 REPLIES 11
Message 2 of 12
Re: Star wiring tutorial
are you a BT broadband and phone customer  or with another ISP
for broadband you do not want star wiring in your phone setup/wiring
the first phone socket in your home where openreach incoming wire is connected should be your master socket
Message 3 of 12
Bt broadband.
I would like to try it out so how would I do it?
Message 4 of 12
Star wiring is simply multiple sockets wired to a common point.
Message 5 of 12
So if I have a master socket, and for example 2 extension sockets, what terminals in the master socket should the 2 extensions be connected to for it to be star wiring? A and B or 5 and 2?
Message 6 of 12
I have absolutely no idea why on earth you would want to deliberately star wire sockets, but just common the connections to the other sockets on the incoming terminals A and B
Message 7 of 12
So connect both extension sockets (2 and 5 terminals) to A and B in the master socket with the already incoming bt line?
Message 8 of 12
yes
that should destroy your broadband speed and cause unstable connection
Message 9 of 12
Well, that's a new one on me. Can't understand why anyone would like to have worse broadband
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 10 of 12
I’ve put the incoming bt line wires into A and B in master socket. Then connected 2 external telephone sockets (terminals 2 and 5) to the A and B terminals of the master socket with the incoming bt line and its all fine. No speed decrease, no issues 🙂
