Message 1 of 4
Support With getting compatible and good 2nd modem
Hey i got BT internet and need to get a 2nd modem or switch that way i can add more ports in a different location any tips or advice would be thanked 🙂
3 REPLIES 3
Message 2 of 4
Re: Support With getting compatible and good 2nd modem
All you need is a cheap unmanaged Ethernet switch with the requisite number of ports.
Message 3 of 4
Any recommendations?
Like ubitqidy (cannot spell it soz)
Message 4 of 4
Ubiquity is a mesh system, if you only want extra Ethernet ports you don't need anything like that just a Netgear or Tp Link 4 or 8 port unmanaged Ethernet switch. Are you sure it's just extra ports you want?
TP Link TL-SG108 is about £20 from Amazon
