Message 1 of 8
Sync speed has dropped
Hi, I have noticed my sync speed has dropped recently from around 19Mbps to 15Mbps. We had a power cut the other day so not sure if that has caused the issue and put me on a banded profile. I rebooted just now and it has went from 14.5 up to 15.5. Can a mod have a look at this. I know it's not a massive drop but I do notice it with my relatively slow connection. ThanksScreenshot (30).png
7 REPLIES 7
Message 2 of 8
Re: Sync speed has dropped
If your speed increased after your reset then you are certainly not in banded profile  just need to maintain a stable connection and then you should get back the few mbs that you have dropped
Message 3 of 8
So any idea why it's dropped me 4-5Mbps overnight?
Message 4 of 8
Perhaps because the stats show only 6 mins uptime?
Message 5 of 8
Did you even read my post before being smart?
Message 6 of 8
Keep it friendly guys.
Cheers
David
Message 7 of 8
?? I'm only asking for assistance on why my speed has dropped by around 20% I clearly stated in my op that I had just rebooted. Can anyone on here look into it?
Message 8 of 8
Hi @Craigyrfc and thanks for posting.
@imjolly advice is spot on. You're not in banded profile so the connection will improve automatically if it remains stable.
Cheers
David
