Message 1 of 5
Temporarily turn off parental controls... no longer works
Hi all,
I have lost the feature to turn off Parental Controls temporarily (for one hour).
If I try to access a blocked website, I just get a 'Forbidden' message with no further options.
I can still turn off Parental Controls by fully logging in etc, although the original feature worked well.
Any ideas?
Thanks all
4 REPLIES 4
Message 2 of 5
Re: Temporarily turn off parental controls... no longer works
Hi @cordycordy and welcome back.
Thanks for posting about the parental controls, sorry you're having problems with it. We'll need to take a closer look at this for you so I'll drop you a private message now so you can get in touch.
Cheers
David
Message 3 of 5
Hi all,
Reposting this...
I have lost the feature to turn off BT Parental Controls temporarily (for one hour). If I try to access a blocked website, I just get an 'Error 403 Forbidden' message with no further options. I can still turn off Parental Controls by fully logging in etc, although the original feature worked well. Any ideas? Thanks all
I had a call from BT who  were as perplexed as I am - they suggested it could be a popup/ad blocker - I've checked all that, still no luck. I've also gone back to factory settings on my hub.
FYI, if I connect to open BTWi-Fi (rather than my usual hub connection), it works fine.
I have the same issue with multiple devices and multiple browsers. I've tried to see if there is a setting in my Smart Hub Manager settings, although again no luck. It's not a major issue... but niggling!
Thanks all
Message 4 of 5
Hi all,
Reposting this as still not resolved...
Message 5 of 5
Hi @cordycordy  welcome back and sorry that the fault with the Parental Controls has not been fixed for you. We do send these cases to a specialist offline team. I've sent you a Private Message so you get back in touch with us and we'll check to see what has happened to your previous complaint.
cheers
John
