Message 1 of 7
The site is blocked
Hello.
I don't know where to write about my problem. It turns out that bt is blocking access to stereoshore.com - Warning: you could be getting scammed! But the site doesn't collect any data or scam anyone, check it for yourself.
Please, remove this warning.
6 REPLIES 6
Message 2 of 7
Re: The site is blocked
It's probably the website that has an issue with their security certificate...
Message 3 of 7
I've just tried the site and it works fine on 4G BT Mobile
Message 4 of 7
Have you got web protect enabled?
Message 5 of 7
Works fine for me using any browser. I do not use web protect (if that is the cause).
Message 6 of 7
Thank you, NigelB72.
Moderators, you can delete this topic if you want. Thanks again.
Message 7 of 7
Did you get this fixed? I'm having the same problem on BT Internet, but 4G and other providers work fine.
