Message 1 of 8
UpNp won't enable
I'm trying to port forward my Minecraft server, but UpNp is unchecked, and no matter what I do, it won't turn on.Screenshot 2021-01-10 201310.png
Please help, I've been trying to do this for the past three days and nothings working.
My router is BT Smart Hub 2
7 REPLIES 7
Message 2 of 8
Re: UpNp won't enable
First of all if you are manually forwarding ports, it is best to disable UPnP anyway to avoid conflicts.
Secondly, do you mean it is disabled and you are unable to enable it? You could try a factory reset of the hub and start again. Remember to turn off smart setup after the reset.
As said previously, I don't believe your problems are with port forwarding.
Message 3 of 8
No, its enabled, but it isn't ticked in the port forwarding section.Screenshot 2021-01-12 143604.png
Message 4 of 8
I have no idea why UPnP should be ticked when ports are manually forwarded or why that column is even there on a port forwarding screen.
Message 5 of 8
Unfortunately, turning off UpNp still has not worked, and my friend still can't join, should I factory reset my router?
Message 6 of 8
Worth a try.
Message 7 of 8
Even after resetting, turning off UpNp, and making sure Smart Setup is turned off, my friend still cannot join.
Message 8 of 8
As I keep saying, I think you are trying to find the solution in the wrong place.
Have you tried posting on the Minecraft forum (if there is one)
