Message 11 of 38
Re: The way you cast BT Sport is changing
bitrate is not to high. To watch sports we need at least twice more then 6,99 mbps..
Message 12 of 38
Increased bitrate would only help if compression were the cause of the less-than-expected quality. That isn't the case here.
If you want to send me a DM with the BT ID you're logged into the app with, I can at least confirm that you're seeing the best quality stream available.
Message 13 of 38
Of course it wiped help as it’s clearly happening when move on a screen appears..then why would I even care? I pay 25 a month and
it should be much better. But it is really bad.
Message 14 of 38
I've offered to help you @Piotrch and you've chosen not to accept it. There's nothing further I can do for you.
Message 15 of 38
Sorry didnt have time. I’ll send it now.
Message 16 of 38
Well i could complain so I I have to praise. Awesome picture quality in 4K, HDR Atmos..well done
Message 17 of 38
Thank you for posting this.
I have been searching for hours trying to connect my iPad to my TV.
Airplay works perfectly and I am in good time for the lunchtime game.
Very much appreciated
Pete
Message 18 of 38
Have you any update on the LG trial ?
I went through the process of registering on the BT Test and Trials program and your link gives nothing.... I assume you were referring to the 2021/22 Football season ?
Message 19 of 38
Unfortunately there hasn't been any progress with the LG app. The issues are commercial rather than technical.
We are currently investigating the possibility of re-enabling screen mirroring for some devices though, subject to technical restrictions. Not perfect, and won't be "supported" but will at least give an option for some customers.
Anonymous
Not applicable
Message 20 of 38
@humeka
Probably as well to pick up an HDMI stick device that does have the app.
