Message 1 of 21
TrueKey
My true key app says it can't connect to the servers. message is "There seems to be a problem connecting to the True Key servers." It has been working fine for years. Tried on 3 different PC's, same result.
Broadband is working fine..
Any ideas please?
TIA
Bob
20 REPLIES 20
Message 2 of 21
Re: TrueKey
Same for me. Can’t log in on any device.
Message 3 of 21
Re: TrueKey
As a matter of interest kiwi bob, have you just gone on to digital voice, as I have?
Message 4 of 21
Re: TrueKey
Same here.  I have Truekey set up on my laptop and on my android phone.  Neither will log in.  I have also just moved over to digital voice.
I'm trying to get help from BT via the phone, and will update if I find out any more.
Message 5 of 21
Re: TrueKey
Message 6 of 21
Re: TrueKey
I have called for support twice and the phone has rung off without answer twice.
Message 7 of 21
Re: TrueKey
I can log in using data on my iPhone, but not with the Halo 3 WiFi. So it’s definitely BT
Message 8 of 21
Re: TrueKey
Mmmm. Not sure now. I logged out now can’t log in.
Message 9 of 21
Re: TrueKey
Just as well it's not for anything important, like accessing all our online accounts.
Message 10 of 21
Re: TrueKey
Did you know you can log in to truekey off line? You can’t add new logins but you can use your existing ones.
