Message 1 of 4
Unreliable connection
Hi,
My internet connection has been somewhat unreliable for some time now.
Could someone tell me if these router stats look ok?
Product name: BT Hub 6A
Firmware version: SG4B1000E020
Firmware updated: 19-Dec-2020
Board version: 1.0
Gui version: 1.115.0
DSL uptime: 29 Days, 0 Hours 4 Minutes 32 Seconds
Data rate: 20.00 Mbps / 70.66 Mbps
Maximum data rate: 29248 / 70676
Noise margin: 12.6 dB / 5.9 dB
Line attenuation: 20.3 dB
Signal attenuation: 16.7 dB / 20.3 dB
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
3 REPLIES 3
Message 2 of 4
Re: Unreliable connection
They look absolutely fine and you have had 29 days of continuous connection without a single disconnection.
Message 3 of 4
But in status information it says Network uptime: 0 Days, 4 Hours 22 Minutes
Anonymous
Not applicable
Message 4 of 4
Might be worth re-reading the output
