Message 1 of 7
Upgrade from Fibre 100 to Fibre 250 - no change
When I logged on today to see my bill there was the offer to upgrade my service from Fibre 100 to Fibre 250 with speeds of upto 220Mb/s. I thought I would do this for the extra speed and signed up. Within 30 minutes the broadband circuit went down and restarted. Prior to the upgrade I have had 29/159Mb/s for many months and after the upgrade I have exactly the same speed. Have I missed something here as the line speed is in spec for both Fibre 100 and Fibre 250, but I would have expected an increase with the upgrade?
6 REPLIES 6
Message 2 of 7
Re: Upgrade from Fibre 100 to Fibre 250 - no change
Enter phone number here :- https://www.broadbandchecker.btwholesale.com/#/ADSL and post results minus your phone number.
It could be your line is already at its max capability and cannot support fibre 250
Message 3 of 7
Does this help?
Message 4 of 7
That doesn't help as it doesn't show if you have FTTP or G.Fast. Give the FTTP team a ring, they will advise you.0800 587 4787
Message 5 of 7
As far as I am aware Fibre 100 and Fibre 250 are both GFast and FullFibre 500 and FullFibre 900 are FTTP.
Message 6 of 7
It clearly shows the OP has G.fast - FTTP is not available.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 7 of 7
Full Fibre 100 is available of FTTP.
