Message 1 of 8
Upgrading from Home Hub 5 to Home Hub 6
I currently have a Home Hub 5 running and connected to 4 (White) Whole Home Discs.
Apart from the perennial problem of the discs passwords not being recognised so I can't configure them using the app. everything talks to everything else OK. I also have a home cinema also connected wirelessly to one of the discs which was not an easy set up because of the disc non password recognition.
My question is this - If I swap my Home Hub 5 for a Home Hub 6 will I need to go through the laborious task of reconnecting all the discs and projector to the new hub of will they be recognised automatically?
7 REPLIES 7
Message 2 of 8
Re: Upgrading from Home Hub 5 to Home Hub 6
Why do you want to swap your hub 5 for a hub6?
Message 3 of 8
Because it was sent to me as an upgrade from BT and I assume that it's better?
Tell me if it's not and it'll save me a lot of hassle I think!
Message 4 of 8
I am sure @licquorice  will agree, if its not broken, then do not try to fix it.  The HH5 is just fine, especially as you are using a separate wireless network anyway.
Changing it for the HH6, is likely to result in a lot of hassle. The HH6 is supposed to have better  stand alone wireless coverage, that is all.
Anonymous
Not applicable
Message 5 of 8
Personally speaking, I considered the HH6 to be a downgrade on the HH5.
The HH5 just sat there and did what it's supposed to do - no drama, the HH6 on the other hand ...... I'll have to stop there as forum rules don't allow me to use expletives.
Message 6 of 8
Don't believe all the marketing hype, if your hub5 is working, don't change it
Message 7 of 8
Thanks for all your responses guys. I'll leave the Hub 6 in its box.
Message 8 of 8
I recently upgraded to BT Halo with a Smart Hub 2.
I purchased a set of three Whole Home discs independently and had no trouble setting them up up via the Whole Home app.
This is the second time I have used the Whole Home discs and have never had a problem setting them up via the app.
