Message 1 of 22
Use Bt business smart hub at home
I have a spare bt business smart hub from work. Can i use this at my home on bt residential broadband and take advantage of the bridge mode option that only business hubs have?
21 REPLIES 21
Message 2 of 22
Re: Use Bt business smart hub at home
Message 3 of 22
thank you
will i just have to use the same username login details from my current homehub and put that in the business hub?
currently on the business hub it set to : [email protected]
also will the hub still receive future updates and won’t write over the business hub modem mode settings?
Message 4 of 22
yes you need to use the normal residential login  [email protected]   and any password
updates should be ok and automatic
Message 5 of 22
Surely if you are using it in the modem only mode, then PPPoE authentication would be done on your own separate router?
Message 6 of 22
I have fibre 1 service which is fttc (max 80mb)
will i need PPPoA or PPPoE settings for my new router?
and where would i get these settings from?
Message 7 of 22
Im not sure. Hence why I’m asking on here for advice.
Message 8 of 22
PPPoE, not sure what you mean by 'where would I get those settings from'
Message 9 of 22
Ok so this is what im trying to do
use bt busines hub in modem modem and connect my linksys velop and use that as the router
so on the bt hub i change the username to the residential one and on the velop i use PPPoE?
Message 10 of 22
No, the PPPoE username and password are entered on the Linksys. No credentials are required on the hub as a modem. If there is a setting on the hub for VLANid, set it to 101
