Message 1 of 2
Using multiple hubs/ routers
Hi, hoping someone has done this before or can give me some guidance!
My family recently upgraded from a BT hub 5 to a Smart Hub 2, this is working great but I want to utilise the hub 5 as well.  This is to be used for a second network for use in audio recording at home, as well as using externally to run live sound at gigs etc. My plan is to use a powerline ethernet connection from the smart hub to the hub 5, allowing the internet to pass through and from there into my laptop. The hub 5 will also have audio equipment linked to it that I want to use with the laptop outside the house, hence the need for the hub.
I have tried to set it up but cant make the internet pass through consistently. What settings to I need to change in which hub and should I plug the powerline into the red WAN socket or the yellow gigabit socket on the hub 5.
TIA
1 REPLY 1
Message 2 of 2
Re: Using multiple hubs/ routers
Give the Hub 5 an IP address outside of the DHCP range of the SH2, turn off DHCP on the hub 5 and connect the 2 hubs LAN port to LAN port via the power line adaptors.
