Message 1 of 2
V0.27.07.07281-BT Has broken 2.4 Ghz Wifi
My Smart Hub 2 was upgraded to v0.27.07.07281-BT overnight and now this morning none of my 2.4Ghz devices are able to connect to the WiFi network.
5 Ghz devices can connect fine but 2.4Ghz devices are unable to connect to the WiFi network.
The 2.4 Ghz devices are able to see the SSID but can not connect to it.
Another issue is that the MyBT app installed on a 5Ghz devices can no longer see the network within the “Your WiFi network” option in the app it just keeps asking to connect to router when it’s already connected to the WiFi.
1 REPLY 1
Message 2 of 2
Re: V0.27.07.07281-BT Has broken 2.4 Ghz Wifi
Update - A hard reboot (not a soft one which did not work) fixed this.
