Message 1 of 4
Bt hub making beeping noises
My Bt hub 2 keeps making beeping noises randomly.
The tone is 2 short beeps followed a slightly longer one. The tones occur randomly at no set times. Have checked the BT web site for error messages and wasted an hour looking to no avail.
Any ideas please.
Bob
3 REPLIES 3
Message 2 of 4
Re: Bt hub making beeping noises
Message 3 of 4
Are you sure it's the hub? Maybe turn the hub off for a while in case it's a smoke alarm bleeping
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
Hi @BobSelby,
Thank you for posting. I think @Devon_Dave suggestion is a good one.
I would check your Smoke Alarms as I had a similar beeping sound and it turned out to be the Smoke Alarm letting me know the batteries needed replacing.
Thanks,
Paddy
