Message 1 of 8
VC086 error watching BT Sport on MacBook
Hi
I did search and saw thread on this, but not sure solutions will help me.
Just inherited son's older MacBook (I paid for it), as he has newer one. Tried Chrome and watching in private window but no good. am I  doomed?
7 REPLIES 7
Message 2 of 8
Re: VC086 error watching BT Sport on MacBook
Hi @Longshanks that error normally means your browser is blocking the BT Sport cookies needed to view the stream.
  1. On your computer, open Chrome
  2. At the top right, click More (3 dots)
  3. Click Settings, then Privacy and Security
  4. Select Cookies and other site data
  5. Select Allow all cookies
Let me know if this helps?
Neil
Message 3 of 8
Hi again Neil
Sorry for delay. Taking me f###ing ages to find my way around MacBook structure and terminology. We seem to have “Google” already installed. (When you launch Safari) However, can’t find the three dots at top right. I wonder whether this is Google, but not Chrome. I tried to download and install Chrome, but wanted admin password which I need to get from my son.
I can manage Windows, iPad, iPhone, but the Mac is challenging to me of little brain. Will speak to son tomorrow.
Message 4 of 8
Good Morning @Longshanks
I'm not that familiar with Mac's myself but on the few occasions that I've used one I did think it was a good machine but as you've noticed the layout was a bit baffling for me as well and would take a bit of getting used to.
The instructions I provided were for the Google Chrome browser, Safari is below.
  1. Click the Safari dropdown menu
  2. Select Preferences
  3. Click Privacy in the top panel
  4. Under Block cookies select Never
  5. For increased security, once you have finished using the site, please change the Privacy setting back to Always
I hope that helps?
Message 5 of 8
Hi again Neil
Found that we already had Chrome installed on MacBook. Followed your instructions and it worked.
(Assuming BT Sport won’t work with Safari?)
Message 6 of 8
Hi @Longshanks That's great, I'm glad it worked. Yes BT Sport will work with Safari but you'll need to make sure that it's not blocking cookies. My previous post has the instructions showing you how to check that.
Cheers
Neil
Message 7 of 8
Cheers.
Message 8 of 8
block cookies is unchecked in Safari but still no joy
