Message 21 of 53
Re: The way you cast BT Sport is changing
Have you tried downloading it from the web site, rather than using Firefox to update itself?
Message 22 of 53
yes
Message 23 of 53
so what about safari?
still not had an answer...
Message 24 of 53
what a waste of ffing time this is
thanks for nothing
BT sport expert 😒
Message 25 of 53
My guess is you're on an old unsupported version of MacOS, but I can't be bothered to find out anymore. Your constant abuse means I really don't want to spend any more of my free time helping you out.
Message 26 of 53
Do you have any device perhaps mobile phone or tablet where you could browse to btsport.com and then log in with your Bt id? ,  That's what I do. At least you can then watch the game on that device. You could then cast it to the TV if you have Chromecast or similar.
Best of luck,
Message 27 of 53
@oniontwelvewrote:
yes
Yes what?
Did it work or not?
Message 28 of 53
Minimum Mac OS / browser versions
Checking the Firefox web site, the current minimum supported MacOS version is 10.12.  If you're on an older version of MacOS then you'll only be offered an older version of Firefix, which isn't capable of playing BT Sport (we need Firefox 88 or newer).
I don't know the minimum Safari version we support (I'll find that out tomorrow), but the latest version is 14 which requires MacOS 10.14.  Safari version 10.1.2 was released in 2017, and isn't capable of playing BT Sport.
I'll see if there's any way that we can change the VC089 message to recognise Mac OS versions that aren't supported.
Message 29 of 53
Re: Minimum Mac OS / browser versions
Hi Darren Dev
Thank you for this but I think it was intended for somebody else on this thread re Safari and Mac stuff.
While I am in contact with you I might as well ask you if you have any idea when a bt sport app for LG tv's is likely to turn up because as you know the app can't be downloaded to the WebOS operating system.  Having paid for the app I end up using the website btsport.com most of the time.  You can't go to the website on an LG tv either so it's a poor do for users of LG tvs.
Message 30 of 53
All I can currently say about LG TVs is that it's the most commonly requested platform, and definitely high on our priority list. I can't offer any commitment to when we'll have an app available, but rest assured we'll be shouting it from the rooftops when we do.
