Message 11 of 14
Re: WAN Cable length
Hi pippincp,
yes , that looks like the one I have used.
thanks for replying,
kev
Message 12 of 14
You should wire it as a straight through cable.  Most cables tend to be the 568B standard. The 568A standard is preferred in the USA .
At the end of the day the colour of the cables don't matter as long as they are both the same at either end.
Message 13 of 14
Hi gg30340,
yes, it’s wired straight through as shown.
thanks again,
kev
Message 14 of 14
@Starwire  It's the one I have. Does what it says on the box.
