Message 1 of 2
What WI-FI Disc should be used with a Smart Hub 2 ?
Hi, I have a Smart hub 2 and I'm looking to add a Wi-Fi disc ( I have no Wi-fi Discs at the moment) to improve the signal upstairs and have a couple of questions:
1. I've seen on a non-BT site that the Home Hub 2 is mesh enabled so I do not need to connect a disc direct to it via an ethernet cable - is that correct ?
2. if 1. is true can I connect any of the 3 types of Wi-Fi disc ie mini whole home, whole home and premium whole home, or do some work better with this hub than others  ?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: What WI-FI Disc should be used with a Smart Hub 2 ?
If you wish to connect a Wi-Fi disc without running an ethernet cable to your SH2 then you require the black disc (Complete Wi-Fi)
