Message 1 of 2
Network printers recently appear offline accessed via Whole Home wifi
I have  a BT Smart Hub type A which I've been using without any issues for several years and last year I added a Whole Home system with units connected via wifi and where the location is remote from the main hub the Whole Home unit is connected via ethernet cable.  I have two network printers connected via cable back to the main Smart Hub.  All has been working well with no issues until recently, I found the the printers appeared to be offline.  The only way I could use these printers is by connecting to the router via a network cable or logging into the wifi connection of the Smart Hub.  If I was logged in via the wifi of a Whole Home unit, I couldn't print.
I've spent hours trying to resolve this by updating printer drivers etc but to no avail.  I've also used fixed IP addresses for the printers but nothing has worked.  If I need to print, I cannot use the Whole Home wifi connection.
I'm using PCs with Windows 10 Enterprise and Professional OS.
Any suggestions would be welcome.
David
1 REPLY 1
Message 2 of 2
Re: Network printers recently appear offline accessed via Whole Home wifi
Hi @dwd5031 and welcome.
I'm sorry you're having problems connecting your printers. I've found this thread which is an older post but may be of help. Let me know.
https://community.bt.com/t5/Archive-Staging/Whole-Home-WiFi-and-wireless-printer/td-p/1732029
Cheers
David
