Message 1 of 23
What are these?
Hi everyone can so.einetellme what the 2 bits of kit are in this photo?  Is the stuff on the right what will connect to the property?
22 REPLIES 22
Message 2 of 23
Re: What are these?
Also if this pole is outside my property can fibre be connected?
Message 3 of 23
Re: What are these?
That’s a Fibre Node. Possibly a Splitter but most likely just a Track Joint.
Ref to you being able to get FTTP, depends what that joints there for.
Is there any other furniture at the top of the Pole, specifically a black box that looks like an upside down egg box?
Message 4 of 23
Re: What are these?
On the left looks like a joint box on right a CBT for fibre. Once it goes live you should be able to order.
Ehter your phone number here and post result. Remove number before posting.
@Starwire  What's on the right?
Message 5 of 23
Re: What are these?
Can’t remember it’s technical name as it’s not something I would ever fit.
Its basically to secure the 12 or 36 fibre cable to the pole. It wraps around it in a figure of 8 configuration.
Message 6 of 23
Re: What are these?
Thanks for that @Starwire  I've found a pick of the CBT for the OP (CBT on right).
Message 7 of 23
Re: What are these?
I believe it's FTTP
Did you take the photo yourself or get it off the internet? it's remarkably like this one which carries a brief explanation.
https://www.westlittleton.com/FastBroadband.php
Message 8 of 23
Re: What are these?
2 CBT’s. A 4 Port and a 12 Port.
They always put in enough Ports for each property served. Although I don’t see many existing Drop Cables from that BT76 so unsure if it theres even 16 Working Coppers Circuits off it?
Message 9 of 23
Re: What are these?
Hi all thanks for the replies very helpful.
The image is a stock image as it looks exactly like what I can see but its a good close up.
I've attached the actual pole picture.
There is nothing else like the upside down egg box.
So I guess I'm wondering can this pole supply my house?
Message 10 of 23
Re: What are these?
It cannot as yet.
