Message 1 of 3
What is this box?
Hi,
I’ve found a box like this on my wiring. It’s seems really old and has the incoming wire attached to 2 screws and then the internal wire which connects to master socket A and B attached to another 2 screws.
Could this box be the reason why I suffer from high ping and slow speeds?
2 REPLIES 2
Message 2 of 3
Re: What is this box?
as long as no corrosion on terminals that is normal for connecting incoming openreach wiring to internal home wiring and should not affect your connection
Message 3 of 3
Its a GPO Block Terminal 20/4 fitted with dummy fuses and will have absolutely no impact on your service whatsoever as long as there is no corrosion as @imjolly  says.
