Message 1 of 5
Where do I find a security key
4 REPLIES 4
Message 2 of 5
Re: Where do I find a security key
Hi, the WI-Fi key, network name & admin password are all on a sticker on the back of the Hub for recent models, older models have it printed underneath.   https://www.bt.com/help/broadband/where-do-i-find-the-default-admin-password-for-my-bt-hub-
Message 3 of 5
You will need to be more specific. What security key are you looking for?
Message 4 of 5
No worries! It's the signing-in code on the back of the BT Hub that I used to connect to the internet.
Message 5 of 5
Thanks, I found it and used it to set up my range extender already
