Message 1 of 8
Where do I plug my router
After many problems the PON light on my ONT has changed to solid green. I rang bt today and they said they cant activate it yet. However where do I plug my router into? It says the port socket however ive already got something in that which goes into the wall. Theres connections that the red cable fits into in the living room and bedroom. Ive attached a picture too.
7 REPLIES 7
Message 2 of 8
Re: Where do I plug my router
The grey lead from the ONT either plugs directly into your router if it is sited adjacent to the ONT or you plug it into the socket that is at the other end of the patch panel that the ONT is currently plugged into.
Message 3 of 8
The ONT is in the cupboard under the stairs so wouldn't that effect the wifi quality?
Theres a two holes that it fits into in the living room one turns the light orange and the other turns the light a flashing purple (not activated yet)
Message 4 of 8
You can site the router where you like. You need to discover which socket on the patch panel goes to where.
Message 5 of 8
Thank you, theres nothing saying which one it is at my house which i assume is a developer issue. It fits into the one named “alarm” which turns the light orange, the other turns it a flashing purple. Il have a play about with it once its activated
Message 6 of 8
Hopefully your developer should be able to provide a diagram of what is connected to where.
The socket that gives the orange light is the one connected to the ONT.
Message 7 of 8
So I plug it in that one?
Message 8 of 8
