Message 1 of 6
Unable to connect to my FTP client
After a couple of years without problems a few weeks ago I found I was unable to send emails via Microsoft Outlook and also unable to contact my FTP client to edit a website.
I ran a tracert and found the block appears to be a BT server. How is this solved?
If I use a VPN the problems disappear, however I shouldn't have to pay extra for a VPN to use BT broadband.
Anyone else having this problem or solved it?
5 REPLIES 5
Message 2 of 6
Re: Unable to connect to my FTP client
Message 3 of 6
Correct it was switched on, I had no idea I had it. I'll wait a couple of hours and see if switching off solves the problem.
Message 4 of 6
Thanks for posting @Grayfly .
Please let us know if @licquorice suggestion sorts this for you.
Cheers
David
Message 5 of 6
Hi
Yes, that appears to have worked.
Thanks to all.
Message 6 of 6
Thanks for letting me know @Grayfly .
Cheers
David
