Message 21 of 25
Re: Whole Home Wi-Fi v1.02.13 build07 Full Release
Does anybody know what this in the logs "Added into unfriendly station list(AP_ROAM)rec(626214)dur(3600)"?
Message 22 of 25
I updated my 5-disc system this evening and it all went well with the entire mesh back up and stable inside 15 minutes.
Message 23 of 25
I have a four disc system and, because of problems with firmware upgrades back in the mists of time, I am in the habit of turning off the two most distant discs and updating the other two and seeing if they are OK before turning the other two back on.
Upgraded the first two a few days ago without any issues and have just turned the others back on. They updated themselves automatically and all appear to be performing well.
Message 24 of 25
@ Leilabd
I used to do this myself a while back with 1 disc before we had BT add a roll back menu, this can be found
http://mybtdevice.home/rollback.htm
or http://**********/rollback.htm
replace **** with your IP
(The above is use in a browser not in app)
Message 25 of 25
Hi John Build 7 is over a year old now are there any plans to update the firmware? Roger
