Message 1 of 1
Wi-fi away from home
Hi,
I can connect to wi-fi no problem when I'm away from home in friends' houses - except to use gmail, google and youtube (whatever the common denominator is for those sites).  Other sites load/connect without problem.  I HAVE been able to use these flawlessly many times, but the last few days - and, previously, for other days-at-a-time - they won't work.  (1) What's the problem; and (2) why have I been able to connect many times but sometimes not?  Strangely, I CAN always use the sites on my Android phone through the same wi-fi connection - but not my Windows laptop.
To be clear, I can connect to wi-fi - it's just these sites that intermittently won't work.  As soon as I'm home and using my own router, all sites work.
The BT wi-fi address used to connect: https://www.btwifi.com:8443/home
If you can kindly advise why and/or a solution, thanks so much.
Many thanks,
Marcus
