Message 1 of 5
WiFi disc
I want to set up a WiFi disc in a location too far from the Hub2. As it cannot consistently connect to the hub through WiFi, can I connect it using an existing Cat 5e network?
4 REPLIES 4
Message 2 of 5
Re: WiFi disc
Of course and it's the best way to do it.
Cheers
Ted
Message 3 of 5
Re: WiFi disc
@graywallis Do you have a complete wifi subscription? If you do we can provide up to 3 discs if one is not providing enough wifi coverage. Additional discs link together as part of a mesh network extending it to where you need it.
Neil
Message 4 of 5
Re: WiFi disc
Thanks.
Message 5 of 5
Re: WiFi disc
There is a shortage of convenient power outlets and an existing Cat5 LAN.
