Message 1 of 2
Wifi Disc
I recently got the 500mbps Package and I purchased one whole home broadband disc from Currys PC World, I cannot get it to link my disc to my router, Ive bought it for better connectivity Upstairs, And it wont link via wps, I only have the one disc though
1 REPLY 1
Message 2 of 2
Re: Wifi Disc
@Reidyy
If it a Whole Home Disc, then you cannot link it to the BT Smart Hub 2. Only the black BT Complete WIFI discs connect to the home hub using Wi-Fi.
If you use the Whole Home Discs, then you need a minimum of two, and one must always be connected to an Ethernet port on the home hub.
