Message 1 of 2
Xbox Series X and Smarthub wi-fi slow?
Hello, I have a Xbox Series X and a BT Smarthub 2. The problem I having is that my Xbox takes over thirty seconds to connect to by smarthub, it used to connect immediately.
It was suggested to turn off Smart Setup but I don’t have that option in my settings. I’ve also reset my hub and tried resetting the network settings o my Xbox but nothing has worked.
Is there anything else to try?
1 REPLY 1
Message 2 of 2
Re: Xbox Series X and Smarthub wi-fi slow?
Hi @Marc123 thanks for posting. Smart set up is switched off in Smart Hub 2 settings, this link shows you how to do it.
Neil
